HARDCORE Posted December 24, 2012 Share Posted December 24, 2012 I too would be very tempted by one of these when you have some available Quote Link to comment Share on other sites More sharing options...
mad dog Posted December 24, 2012 Share Posted December 24, 2012 Hi, I'm really interested in one of these mods. I can source a Manta column and a Corsa power steering column without switch if you're struggling. Quote Link to comment Share on other sites More sharing options...
youngron Posted October 19, 2015 Share Posted October 19, 2015 Hi there can i order one of these kits its of my cadet but i think its quiet similar 07747755848 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 20, 2015 Author Share Posted October 20, 2015 Hi there can i order one of these kits its of my cadet but i think its quiet similar 07747755848 While they look similar the manta kit won't fit the Kadett as the dash is a different shape. You can fit a corsa B epas column to it but would need to make the brackets from scratch. i did sell a couple of corsa columns to people fitting them in Kadetts but they were standard columns and for them to fit themselves (one was a lhd if i remember rightly) Quote Link to comment Share on other sites More sharing options...
shonky opels Posted October 31, 2015 Share Posted October 31, 2015 Are you still making these fella? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 1, 2015 Author Share Posted November 1, 2015 PM sent Quote Link to comment Share on other sites More sharing options...
maddave28 Posted November 8, 2015 Share Posted November 8, 2015 I know that this is a very old topic but is it still possible to get a column from yourself Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 8, 2015 Author Share Posted November 8, 2015 Yes i can still provide these. Shipped one to Ireland last month and have one on the bench that is going up to Scotland soon I only make them to order nowadays, i'll send you a PM about it. Quote Link to comment Share on other sites More sharing options...
Alexmac329 Posted November 8, 2015 Share Posted November 8, 2015 Can you make one up for me I would be intrested in one for my manta b Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 8, 2015 Author Share Posted November 8, 2015 I have most of the parts in stock but am currently out of donor manta columns, although am on the hunt for some more. In the meantime if you can send me your manta column i can convert it and return the Epas kit within a couple of days ready to fit. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted November 11, 2015 Share Posted November 11, 2015 Hi, mantasrme, which year corsas do I need to look out for? Quote Link to comment Share on other sites More sharing options...
mantaray Posted November 11, 2015 Share Posted November 11, 2015 Hi david. Is your price still the same ? £190 Chris. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 12, 2015 Author Share Posted November 12, 2015 Hi, mantasrme, which year corsas do I need to look out for? Its the column from a corsa B which is around 1994-2000 but not all of them had the electric column, some didn't have power steering and some others had hydraulic power steering, it was mostly the later cars and above base spec that had the EPAS columns fitted. So can be a bit of a hunt around the yards. If you can find one in a local breakers yard and remove it yourself you can get a fair price for one, more so if they don't know what they sell for on e-Bay. Just make sure you get the ECU, lower link and also the blue power plug. If buying from e-bay the columns are currently selling for £100- £180 untested and often without the blue plug (others are selling the plug at £10) Hi david. Is your price still the same ? £190 Chris. The price has gone up a bit since i originally posted this advert 3 years ago (as most things have in that time) largely due to the increase in Corsa column prices but the other parts have also crept up. Its currently £240 for the kit plus £20 p+p with a further £30 exchange available for your old manta column. Currently i am out of manta columns so they are only available on an exchange basis, needing your manta column to use for the conversion i can have it done and heading back to you in a couple of days for £230 all in The basic kit is the same as it was but now includes a bracket to hang the ecu bellow the washer bottle tray and new lengths of wire fitted to the power plug with the correct crimp terminals (sourced from the USA in bulk) Also included are all the terminals required to fit the kit, heat shrink, a fuse holder and fuse, the blue power plug with wire (1.5m red 0.5m brown so plenty for the power and earth) The manta lower bearing is stripped and the bearings replaced and all re-greased. Plus of course the speed signal box and adjuster to make it all work. 1 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted November 14, 2015 Share Posted November 14, 2015 many thanks, if I find my own Corsa parts and a spare Manta column, can you do the conversion for me? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 14, 2015 Author Share Posted November 14, 2015 many thanks, if I find my own Corsa parts and a spare Manta column, can you do the conversion for me? Yep no problem, have just done one like that for someone, that would be £140 That gets your corsa column checked and the torque sensor adjusted if required, both columns stripped, lower bearing re-built, bracket parts blasted then modified on my jig, ecu bracket built, everything painted, all the wiring stuff inc fuse and holder, speed controller etc, then boxed and shipped back to you. Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted November 14, 2015 Share Posted November 14, 2015 I have bare manta steering columns available to suit this conversion complete with top and bottom bearings at £30 plus £10 p&p if that's of any help to anyone :-) Carl Quote Link to comment Share on other sites More sharing options...
Snowy Posted November 19, 2015 Share Posted November 19, 2015 Yep no problem, have just done one like that for someone, that would be £140 That gets your corsa column checked and the torque sensor adjusted if required, both columns stripped, lower bearing re-built, bracket parts blasted then modified on my jig, ecu bracket built, everything painted, all the wiring stuff inc fuse and holder, speed controller etc, then boxed and shipped back to you. What year corsa power steering motor do you need? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 19, 2015 Author Share Posted November 19, 2015 What year corsa power steering motor do you need? I posted it further up in the thread mate Its the column from a corsa B which is around 1994-2000 but not all of them had the electric column, some didn't have power steering and some others had hydraulic power steering, it was mostly the later cars and above base spec that had the EPAS columns fitted. So can be a bit of a hunt around the yards. If you can find one in a local breakers yard and remove it yourself you can get a fair price for one, more so if they don't know what they sell for on e-Bay. Just make sure you get the ECU, lower link and also the blue power plug. If buying from e-bay the columns are currently selling for £100- £180 untested and often without the blue plug (others are selling the plug at £10) Quote Link to comment Share on other sites More sharing options...
Peter Higgins Posted January 26, 2016 Share Posted January 26, 2016 On 19 November 2015 at 3:00 PM, mantasrme said: Hi I am interested in a power steering column. Are you still making them or have you any in stock. How much would it be to post to Northern Ireland. Peter Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 27, 2016 Author Share Posted January 27, 2016 Yes i'm still making them, you have a PM Peter 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 27, 2016 Share Posted January 27, 2016 Great kit, made my own about 8 yrs ago, .....shit, time flies! Motor mounted to left knee, even kept my original column. Only modification was two holes needed drilled. Great job, and helps trying to park with 8 inch ats up front! Worth while conversion. Quote Link to comment Share on other sites More sharing options...
robah Posted January 27, 2016 Share Posted January 27, 2016 21 hours ago, mantasrme said: Yes i'm still making them, you have a PM Peter I have most of the components to do this Mod, might have to send it over to you David to build up for me, as a future spare steering column. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 28, 2016 Author Share Posted January 28, 2016 On 27/01/2016 at 0:37 AM, brady said: Great kit, made my own about 8 yrs ago, .....shit, time flies! Motor mounted to left knee, even kept my original column. Only modification was two holes needed drilled. Great job, and helps trying to park with 8 inch ats up front! Worth while conversion. Yeah, drill 2 holes for rear mount of column, trim the lower dash a little and connect 6 wires. Really is a simple fit. 14 hours ago, robah said: I have most of the components to do this Mod, might have to send it over to you David to build up for me, as a future spare steering column. No problem Rob, i can do that for you. Have done a couple like that already for people. 1 Quote Link to comment Share on other sites More sharing options...
youngron Posted March 3, 2016 Share Posted March 3, 2016 Have you anymore of these kits need one for my kadett c coupe please 07747755848 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 3, 2016 Author Share Posted March 3, 2016 1 hour ago, youngron said: Have you anymore of these kits need one for my kadett c coupe please 07747755848 These kits will not fit the Kadett i'm afraid, and i have not done one for that as i have never had one in to work out the prototype. Quote Link to comment Share on other sites More sharing options...
