1200bandit Posted September 7, 2019 Author Share Posted September 7, 2019 (edited) So here’s some photos of the epic paint runs Had a look on YouTube found some ways to remove the runs. Had a quick go at scraping of the runs (Have a look on YouTube) Removed one run (by the filler neck is now gone). Just needs a polish No time to carry on with now may be on Monday night Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited September 7, 2019 by 1200bandit Quote Link to comment Share on other sites More sharing options...
IanMc Posted September 7, 2019 Share Posted September 7, 2019 Its a very fine line between max gloss and runs isn't it? - dont beat yourself up mate, remember we are not Pro's! Anyway... its the final result that counts! Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 7, 2019 Author Share Posted September 7, 2019 The runs by the filler neck have now gone, hopefully will get to the paint work on Monday/ Tuesday I think the runs will go and no one will ever notice Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 7, 2019 Share Posted September 7, 2019 At least you know plenty of paint is on. i tried the scraper method some years ago, never got it to work properly. My method is block it down with Wet 500+ grit and flat firm block, then a flash coat to gloss it back, and machine it back in. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 7, 2019 Author Share Posted September 7, 2019 I seen that the was runs when l was painting it ,so put more paint on so when it gets flattened hopefully the will be more than enough paint on the panels that it turns out spot on Quote Link to comment Share on other sites More sharing options...
droop snoot hp firenza Posted September 8, 2019 Share Posted September 8, 2019 when you have flated the runs out. if you take to much paint of you could probabley just repaint that patch. let it dry. then wet and dry over the new and old paint with 1200 grit. then polish up. it works well with 2k but do not no much about your paint. but it should work Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 8, 2019 Author Share Posted September 8, 2019 The runs by the filler neck have now gone, hopefully will get to the paint work on Monday/ Tuesday I think the runs will go and no one will ever notice Got a few hours today had a go of removing the runs , one on the door flattened ok The ones on the lower rear 1/4 not so good, Now l run out of paint, going to use a rattle can on the lower bits Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted September 8, 2019 Share Posted September 8, 2019 (edited) Just a heads up on the removal of runs, you can use the dolphin glaze method. Basically it's a very fine filler, you just smeer it over the run and around the area. This way you are flatting the runs/high spots and the dolphin glaze rather than the paint around the run, it prevents you breaking through the paint around the run. There's lots of videos of this method on YouTube. Hope this helps. Edited September 8, 2019 by ANDY ABBOTT 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 10, 2019 Author Share Posted September 10, 2019 Hopefully will have some time tomorrow night to get the body runs, clean ,paint the rear brake drums (have given them a very quick rub down Will post photos of the results (good or bad) Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 10, 2019 Share Posted September 10, 2019 Great work as always,. Top tip about the dolphin glaze 👍 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 10, 2019 Author Share Posted September 10, 2019 Had a some time so sorted out the petrol flap looking good will need a bit of a polish Before and after Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 11, 2019 Author Share Posted September 11, 2019 Tonight espoused Flatted the panels ,polished the panels, The door and rear 1/4 has turned out very good Had a look a the lower trim, come up really well Refitted the lower trim, petrol flap Adjust the the o/s rear brakes, Waxed oiled the inner sills, chassis Fitted the wheels back on with locking nuts Tomorrow’s espoused (If l get the time) Fit the new aerial to the o/s wing , put it back on the floor and see if it starts (all has in the past) Clean up the garage when sticky starts Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 11, 2019 Author Share Posted September 11, 2019 On 08/09/2019 at 19:58, ANDY ABBOTT said: Just a heads up on the removal of runs, you can use the dolphin glaze method. Basically it's a very fine filler, you just smeer it over the run and around the area. This way you are flatting the runs/high spots and the dolphin glaze rather than the paint around the run, it prevents you breaking through the paint around the run. There's lots of videos of this method on YouTube. Hope this helps. Thanks for the information, had a look at this on YouTube, looks like a good way to remove runs , but have got to get it done quickly as my time is not my own at the minute and has to be sold soon Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 11, 2019 Author Share Posted September 11, 2019 On 07/09/2019 at 21:31, Jessopia74 said: At least you know plenty of paint is on. i tried the scraper method some years ago, never got it to work properly. My method is block it down with Wet 500+ grit and flat firm block, then a flash coat to gloss it back, and machine it back in. I scraped a lot of the runs down then used 500 grit ,then 1500 (much used 1500) wet and dry I have some soft rubber sanding blocks which is very worn so finish off with that , the paint looked shiny before l polish it Had to paint the lower rear 1/4 under the rear bumper, As l was painting it my arse turned on the tap in the garage when l turned around to turn it of the air line go’s in the wet fresh paint under the bumper Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 12, 2019 Share Posted September 12, 2019 Ouch, that is a series of unfortunate events. Water and paint Had my fair share of water causing me problems in the past. Sneaks out even when you think you have completely dried the panels ! Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 12, 2019 Author Share Posted September 12, 2019 To night fitted the aerial to the wing ,had to go into the engine bay ,that’s as far as l got as it’s raining All painting has now been done Back on its wheels, Started fist time runs sweet Sticky on the drive getting all wet Going to put it on some more sites tonight,Possibly on eBay on Saturday (hate putting cars on eBay) Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 3 Quote Link to comment Share on other sites More sharing options...
IanMc Posted September 12, 2019 Share Posted September 12, 2019 Lovely job Wayne! I know it hurts you, but I wish you well with the reluctant sale matey Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 12, 2019 Author Share Posted September 12, 2019 (edited) The paint job is not 100% percent but has turned out a lot better than expected,l impressed myself Got to do a few little jobs noting major Will miss working on sticky Edited September 12, 2019 by 1200bandit Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 12, 2019 Share Posted September 12, 2019 Will make someone a lovely car, it does look so nice 👍 Quote Link to comment Share on other sites More sharing options...
TheRealExile Posted September 13, 2019 Share Posted September 13, 2019 Looks very tidy, nice solid Manta for someone 👍 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 13, 2019 Author Share Posted September 13, 2019 (edited) Someone is showing up tomorrow afternoon to have a look maybe buying sticky It will be a sad day when it gets sold, but it has to go, as we all know Mantas don’t do well outside Replaced the rear drums, the ones on the car where a bit knackered And to think l was doing 90/95 mph on the motorway Also tonight remove the o/s door trim, very surprised to find NO body filler in the door Wax oiled the door when the trim was off ,door mirror fitted as well. Going to clean the engine bay tomorrow, remove the n/s door trim and check ,wax oil the door I know it may be sold tomorrow but l what it as good as it can be Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited September 13, 2019 by 1200bandit 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 13, 2019 Share Posted September 13, 2019 Yeah I think you was right about those drums. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 13, 2019 Author Share Posted September 13, 2019 When l check them l was a more than a bit lucky l got home , I heard a scraping noise when going in and out of the garage just happy that l have not used the manta as things may have gone tits up But l know that when someone else has it the brake drums are good If Sticky gets sold tomorrow so be it , but this is something l always wanted to do 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 14, 2019 Author Share Posted September 14, 2019 Sticky looking very clean and waiting for someone to show up Back it out of the garage remove the n/s door trim , found the wiring to the central locking snapped, repaired the wiring , checked the door again NO body filler in the door ,waxed oiled the door Had a little test drive (the last time was in May) Drives really well Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Just got a text saying he can’t make today Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 16, 2019 Author Share Posted September 16, 2019 On Sunday check things on sticky, found the heater motor inoperative checked the wiring, wiring ok, checked the switch, switch ok put 12 votes to the motor, motor working ok , Clean the wiring conditions, Fit it all back together and now working great Always the way when selling anything Quote Link to comment Share on other sites More sharing options...
