hello
stumpy
thanks guys ,ime trying to figure out how to post pics
its a gold manta 1.8 berlinetta coupe i think its aan old car of a member here or an ex member maybe
if any of you guys could help with posting pics be much appreciated
Edited by stumpy
Hi Stumpy
Welcome to the OMOC, we have a few active members based in S Wales in the Swansea  area one in Tintern & Myself & two others based across the water in Bristol.
We normally meet up regularly during the Spring/Summer/Autumn period but obviously with Covid-19 not possible at the moment.
great to know ide be up for that  when this virus exhausts itself though my car looks nothing like any  of yours pics yet ive spent today cutting a completely rotte front panel off
100866129-10158824464047240-222157408441
8 minutes ago, Jessopia74 said:
Inner wings look good, what’s the Swan necks like ?
Great car for a Redtop conversion as you already have sump, mountings, half hoses and the right gearbox👍
inner wings largely good  the swan necks are untouched   will need floors  and a few patches  i will be letting in any new steel edge to edge for a seamless finish  it started yesterday and sounds fantastic [full stainless pipe]  its been sat at least 7 years  so i was chuffed to bits that she fired second turn and a pump of the pedal even had old fuel in her  i have an xe motor and twin 45 webbers with inlet
Edited by stumpy
oh god i dont know if thats good or bad lol ime made up someone recognises it  and makes me more determined to save her  ime sure though that it used to be red theres a hint of red on the underside of the  4 slot grill and on the iner cills tho its very very dull hardly red at all more like a primer
Edited by stumpy
the sills are solid as are the inners haha  clever old fella i was wondering why i had expanding foam everywhere its all over the floor inside the car also its in the lower x member at the front  ime chuffed to see the pics thank you very much
Edited by stumpy
Would be really interested to see photos of inner sills and cross member to see what old boy done!.
Once seen a mk1 escort coated from new every year with oil once engine oil was changed, it looked a mess, once cleaned off, the 40+ yr old car was newer than new! Amazing!
Doors dont look too bad, have you ever tried molasses rust treatment, look it up on Youtube, keep meaning to take some before and after shots, but it does work, handy for bolts, suspension parts etc, works on body panels too, less agressive than sand blasting.
the inner lower door frame is shot leaves bits on the drive everytime i open them
is there a lower door frame repair section and can you get lower door skins if so ide rescue them tbh or at least try to    i will get some pics tomorrow the floor has rusted through but the  inner and outer sills are solid
same as the whole nose cone its rusted through everywhere but the lower x member is solid [filled with foam]  i havent tried malasis but i have used brick acid [hydrocloric  and phosphric acid in a yamaha r1 petrol tank that was crusty inside 15 minutes checed and drained it refilled through a seive to catch particles then repeated twice the tan was completely 100% rust free
For years & years my cav was jet washed underneath, left to dry off a few days then sprayed with new not old oil, I'm pretty sure that's what saved mine.
As its a "dry" car now I'm steadily cleaning the underside bit by bit, no rush.
Prob cheaper to buy a pair of doors
