611 Posted January 21 Share Posted January 21 Im not sure how well these will come out but i thought i would post some pics of my paint polishing test. This is the process i will be using to polish the old Opel Project when it gets a bit warmer! Give it a clean and use 2000 grit to remove any dirt nibs etc.. The go over it with the Trizact 3000 discs then the Trizact 6000 dics then its onto a bit of refining with the Cartec Final Cut 9000 Then a final finish with Cartec Ultra Finish 12000 and a hand wax finish. Below are some pics of me testing it out on a wing that i below a few coats of paint over if i had any left. I never finished it properly so it was always a bit rough as i wanted to see what it would come out like on this and then hopefully the car would be even better! I used the Trizact 3000, Final Cut 9000, Ultra Finish 12000 and polish on this and missed out the Trizact 6000 as i only have a few of those discs and they are expensive. Im using an Auto Finesse MPX DA Polisher. Hopefully this will be of use to someone and when i get around to the car i will post some of that as well Andy Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 6 Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 21 Share Posted January 21 That’s some job considering it’s a wing you weren’t even really trying to paint! Is the polisher hard to use, is there a certain trick to it? Quote Link to comment Share on other sites More sharing options...
611 Posted January 21 Author Share Posted January 21 (edited) 14 minutes ago, moodoo said: That’s some job considering it’s a wing you weren’t even really trying to paint! Is the polisher hard to use, is there a certain trick to it? Hey Fin I was pretty chuffed with it. As i had that wing spare it was great when i started painting to use as a test to check the gun settings and i also used it to test out getting rid of some runs and now for polishing so its been pretty useful 🙂 The polishing is pretty easy. The thing i have learnt so far is one of the keys is getting the speed right. For the Trizact you can go relatively slow About 1/3 speed seems good and with the cutting compound too slow and it doesn't give you a good finish and too fast and its hard to keep the polisher flat and stable. Cartec said to go on about setting 4 which is about 2/3. You also need to just take your time and be really slow doing it with the 9000 compound as too quick across the panel and again you dont get a good finish. You just use the weight of the polisher, no need to press down on it just keep it level and go slow. Its quite hard to find many good videos that actually talk you through the process properly. Im going to try and find a few more to watch before i tackle the car (and will post if i find a good one) and i need some warmer weather!! This one was quite interesting - www.youtube.com/watch?v=BSPbjicdrkE Its going to be a boring job doing the whole car!! Andy Edited January 21 by 611 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 21 Share Posted January 21 That come out very well .l whoud be very happy with that 1 Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 21 Share Posted January 21 44 minutes ago, 611 said: Its quite hard to find many good videos that actually talk you through the process properly. You’ll have to make one!!👍 1 Quote Link to comment Share on other sites More sharing options...
611 Posted January 21 Author Share Posted January 21 10 minutes ago, moodoo said: You’ll have to make one!!👍 Maybe i can do one and pop it on the blog 🙂 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 21 Share Posted January 21 I am going to attempt this ,hopefully l will get it right, if not a respray will be required If you can do some tips it may stop a repaint Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 21 Share Posted January 21 Could never understand how bodyshops polish soon after paint, or cutting as they call it, its probably only skin, think it takes a good 4 weeks before paint is fully cured. Great effort, looks very well. Quote Link to comment Share on other sites More sharing options...
611 Posted January 22 Author Share Posted January 22 10 hours ago, ®evo03 said: Could never understand how bodyshops polish soon after paint, or cutting as they call it, its probably only skin, think it takes a good 4 weeks before paint is fully cured. Great effort, looks very well. When i was first starting out and reading up on painting they recon you should mop and polish (probably not use the trizact stuff) as soon as the paint is dry as they recon it cuts and polishes better with less scratching than if you leave it to cure as then its much harder to do as the paint is harder and takes more work!! Im sure people will have different opinions. 11 hours ago, 1200bandit said: I am going to attempt this ,hopefully l will get it right, if not a respray will be required If you can do some tips it may stop a repaint Is this on your current car? because if it is then depending on the sort of scratches you have you could use the Cartec 3000, then the 9000 and finally the 12000 to restore it. The Trizact dics are great it you need to get rid of a lot of scratching or have flatted to get rid of imperfections or orange peel. It takes off hardly any paint and reading up if you are using the DA polisher and not the standard grinder style mop then the chances of burning the paint are almost gone as the DA will never burn the paint like the standard spinning sanders. You can get a hand pad if you wanted to be careful when doing the bit with the Trizact dics as i did a hand test on and small bit with the whole process and that came out pretty good. I will see if i can find the link as i have a hand pad i got from ebay. The trizact discs are expensive but the body shop guy recorded you could do a whole car with just 2 and there are some guys on ebay selling just a couple of discs for about £7.00 Im going to do the door first on the car so i will get some more pics when doing it. Lots of youtube watching is key 🙂 Quote Link to comment Share on other sites More sharing options...
611 Posted January 23 Author Share Posted January 23 Although i was supposed be be doing DIY all day today! The missus popped out for a while and the weather was not too cold so i got an hour on the Opel and have started on the door. Took the dust nibs and any imperfections out and hopefully later in the week i will be able to get a few hours and do some cutting and polishing done while she is at work 🙂 Andy Project images are available to Club Members Only, Click to become an OMOC Member. 4 Quote Link to comment Share on other sites More sharing options...
611 Posted January 27 Author Share Posted January 27 As today was a nice day, dry and not too cold. It was time to properly test out the cutting and polishing. I spoke to the tech guys at Cartec and got a bit of advise on mop speeds etc.. So the order below is: Trizact 3000 Trizact 6000 Cartec 9000 cutting compound 2 goes as the guy from cartec said it would gibe a better cut and deeper shine with 2 passes. Cartec 12000 finishing compound Polish and fit chrome! Just the rest of the car to do now!! Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 6 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 27 Share Posted January 27 It's a lot of work, but will really pay off. Looks great, can see the difference. Be amazing in the Sunshine 😎 Quote Link to comment Share on other sites More sharing options...
611 Posted January 27 Author Share Posted January 27 2 hours ago, Jessopia74 said: It's a lot of work, but will really pay off. Looks great, can see the difference. Be amazing in the Sunshine 😎 Its not so much hard work but just time consuming and im not the most patient person 🙂 Think i will do it in stages rather than try to tackle it all in one go! Im looking foreword to getting all the chrome back on it now 🙂 1 Quote Link to comment Share on other sites More sharing options...
611 Posted February 1 Author Share Posted February 1 Backend all polished and bumper fitted and the new number plate lights (that i have had tucked away for years!) have gone in. Bulbs are on their way and i just need to get some new number plates, fit the boot lock and polish the boot lid and that's the backend done. Then on to the front, polishing and bumper fitting! Hopefully all polished and ready for the end of Feb 🙂 Andy Project images are available to Club Members Only, Click to become an OMOC Member. 8 Quote Link to comment Share on other sites More sharing options...
611 Posted February 3 Author Share Posted February 3 (edited) Fitting some new bulbs, then lights back in and wire up and hope it all still works 🙂 Project images are available to Club Members Only, Click to become an OMOC Member. Edited February 3 by 611 2 Quote Link to comment Share on other sites More sharing options...
611 Posted February 10 Author Share Posted February 10 Bonnet and front all polished and now ready for the final cut and wax polish. Im getting the whole car all cut in the Catec 9000 and then will give the whole car a final go over with the cartec 12000 and then a wax finish by hand. Project images are available to Club Members Only, Click to become an OMOC Member. 8 Quote Link to comment Share on other sites More sharing options...
Mike. Posted February 10 Share Posted February 10 Now that does look smart, good job 👍 Quote Link to comment Share on other sites More sharing options...
611 Posted February 10 Author Share Posted February 10 1 hour ago, Mike. said: Now that does look smart, good job 👍 Thanks, Mike Its come out far better than i ever could have imagined. Now im really looking foreword to driving it once i have the last few bits sorted. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 11 Share Posted February 11 Well done that man. looking forward to seeing it this year Quote Link to comment Share on other sites More sharing options...
611 Posted February 11 Author Share Posted February 11 4 hours ago, Paul Barrett said: Well done that man. looking forward to seeing it this year Thanks. Im looking foreword to finally getting out to some car meets this year 🙂 Quote Link to comment Share on other sites More sharing options...
611 Posted February 12 Author Share Posted February 12 Just the plates to fit and that's the front finished! Project images are available to Club Members Only, Click to become an OMOC Member. 7 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted February 13 Share Posted February 13 Looks......... Better than new. Top work. Great write up.... Any pics of the gear you use, mop included. Quote Link to comment Share on other sites More sharing options...
H-400 Posted February 13 Share Posted February 13 She looks great Andy,👍 1 Quote Link to comment Share on other sites More sharing options...
611 Posted February 13 Author Share Posted February 13 7 hours ago, ®evo03 said: Looks......... Better than new. Top work. Great write up.... Any pics of the gear you use, mop included. No problem, i will post some pics of the gear used and also what i have learnt from the whole process later this week when i get time. The whole process of polishing has changed my view on the whole painting the car process so i will add those thoughts as well. Im now really looking foreword to getting started on the Lambretta as i think i can get that looking stunning! 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted February 13 Share Posted February 13 Put a few so called professional jobs to shame mate. 1 Quote Link to comment Share on other sites More sharing options...
