IanG Posted December 7, 2022 Author Share Posted December 7, 2022 (edited) To inform any passing uninformed the garage is now officially a GM sanctuary! Project images are available to Club Members Only, Click to become an OMOC Member. Edited December 7, 2022 by IanG 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted December 9, 2022 Author Share Posted December 9, 2022 The cav is back in the hutch, auto box is now smooth as silk thanks to RGC Transmissions at Morley! 3 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 9, 2022 Share Posted December 9, 2022 22 minutes ago, IanG said: The cav is back in the hutch, auto box is now smooth as silk thanks to RGC Transmissions at Morley! Great to hear 👍 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 9, 2022 Share Posted December 9, 2022 thats brilliant. great. do you know what they didto the box to overhaul it ? Quote Link to comment Share on other sites More sharing options...
IanG Posted December 9, 2022 Author Share Posted December 9, 2022 Yep new seals and gaskets reset everything and fitted it, the splash guard needed a mod as the box bell housing was slightly different to the one in the car, replaced the ring gear (original had some damaged teeth), fixed a leak from Speedo drive, fitted my new kick down cable (works a treat) and test drove it for me. Also they noted a few things on the car for me to look at, nothing serious, “while I was under the car I noticed” kinda stuff really helpful. Tried the lockdown on the way home works perfectly, just on the last bit of full throttle, forgot the missus was following me and had to slow down and let her catch up… 2 Quote Link to comment Share on other sites More sharing options...
IanG Posted December 9, 2022 Author Share Posted December 9, 2022 Used wipers on the way home they work but don’t park themselves, is this likely switch or motor, I assume motor….. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 9, 2022 Share Posted December 9, 2022 quite possibly but check the earth lead right under the wiper motor bracket . 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted December 9, 2022 Author Share Posted December 9, 2022 So happy to have my car back I don’t even mind the cold garage, cleaned the earth and all working fine again now thanks! Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted December 10, 2022 Share Posted December 10, 2022 6 hours ago, IanG said: Used wipers on the way home they work but don’t park themselves, is this likely switch or motor, I assume motor….. Possibly not set quite right on the wiper splines or the splines on the motor. Mine weren’t set right and the first time I used them they went down the bonnet not up the screen! 😳. Luckily they had new wiper blades so no harm done. If you adjust them I suggest you do it with them in the elevated position until you know they’re right. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 10, 2022 Share Posted December 10, 2022 Or note position before removing, or ask for a pic of motor arm connected. Quote Link to comment Share on other sites More sharing options...
IanG Posted December 13, 2022 Author Share Posted December 13, 2022 Amazingly it seems my old Manta GTE is still on the road, does anyone know B123UPO, it was white, now blue……… Quote Link to comment Share on other sites More sharing options...
IanG Posted December 18, 2022 Author Share Posted December 18, 2022 Had some time today to fiddle with the car, replaced the fuel tank boot trim and fitted some new HT leads, fired up fine. Can’t anyone tell me a battery that fits under the bonnet with posts the right way around, I have a spare good battery but sadly it’s too tall. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 18, 2022 Share Posted December 18, 2022 20 minutes ago, IanG said: Had some time today to fiddle with the car, replaced the fuel tank boot trim and fitted some new HT leads, fired up fine. Can’t anyone tell me a battery that fits under the bonnet with posts the right way around, I have a spare good battery but sadly it’s too tall. Got to make sure you get the right battery type (code) regardless of the batter technology type. Have a look here; 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted December 18, 2022 Share Posted December 18, 2022 19 minutes ago, IanG said: Had some time today to fiddle with the car, replaced the fuel tank boot trim and fitted some new HT leads, fired up fine. Can’t anyone tell me a battery that fits under the bonnet with posts the right way around, I have a spare good battery but sadly it’s too tall. I’ve tried all sorts of batteries over the years but I think this one has been the best. It still turns the car over even when left for many months. I can’t tell you where to get one from as this turned up in a car I bought. It also has terminals on the front if you want to connect anything else.Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted December 19, 2022 Share Posted December 19, 2022 65% off batteries at GSF Car Parts @IanG. Use code COUNT65 3 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 19, 2022 Share Posted December 19, 2022 the tray will take a 100 size with no problems. (dont let them tell you a 096 is the same !)standard is a 063 .075 is next size up. biggest is always best with batteries. mine is a yuasa and was about £65 from gsf last year. 3 Quote Link to comment Share on other sites More sharing options...
IanG Posted December 20, 2022 Author Share Posted December 20, 2022 Ordered today the family run fun around/shopping trolley! Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 20, 2022 Share Posted December 20, 2022 now at £90 . the discount is already there so still not super cheap but better than rrp price ! Quote Link to comment Share on other sites More sharing options...
1200bandit Posted December 22, 2022 Share Posted December 22, 2022 Have a couple good batteries ( used but good) Can pick up from Liverpool free of charge 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted January 23, 2023 Author Share Posted January 23, 2023 Hmmm local garage tried to fit my Sportex system today downpipe is fouling the auto box, looks like the old downpipe has a kink to clear the box, on to Sportex to see if they do one otherwise it all has to go back to them! 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 23, 2023 Share Posted January 23, 2023 1 hour ago, IanG said: Hmmm local garage tried to fit my Sportex system today downpipe is fouling the auto box, looks like the old downpipe has a kink to clear the box, on to Sportex to see if they do one otherwise it all has to go back to them! I am sure the auto down pipe is different Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 23, 2023 Share Posted January 23, 2023 not sure regarding aftermarket stuff but originals /original style VL239 are the same auto or manual .physically less resonator on 1.6 models. 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted January 23, 2023 Author Share Posted January 23, 2023 Yep laid side by side you can see it’s different angles, still waiting on Sportex to come back…. Quote Link to comment Share on other sites More sharing options...
IanG Posted February 6, 2023 Author Share Posted February 6, 2023 So, Sportex are aware the downpipe won’t fit an auto box car but don’t offer an alternative. Will have to go to a fabricator to get it sorted, meanwhile have been in the garage this weekend and fitted new HT leads and coil, check the plugs and still running too rich so backed the mixture screw off a bit more. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted February 6, 2023 Share Posted February 6, 2023 dont know if theyre any good to you but there are some std VL239 front pipes on ebay now. 1 Quote Link to comment Share on other sites More sharing options...
