SCP Posted November 17, 2010 Share Posted November 17, 2010 (edited) I thought it was about time to sort out my bulging chassis rails so first I made up a jig to keep the front mounting points etc I removed most of the double skin section Then I removed the inner rail front part( sub frame mounting area) cleaned it up an made out of 2mm steel a insert welded them together As I wanted to keep the original look I decided to use GM new rails but could only get driver side ones so had to modify it ,rather than try to bend the middle section to fit I made from 2mm steel the curved part bellow then I fitted the front inner part of rail and the main new straight rear part now it was time to fit the middle inner part to join it all together Then I modified the new driver side outer rail parts to fit after a bit of welding an grinding this is the end result Edited November 17, 2010 by SCP 2 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 17, 2010 Share Posted November 17, 2010 thats prob the best repair ive seen yet of rails! Quote Link to comment Share on other sites More sharing options...
upk Posted November 17, 2010 Share Posted November 17, 2010 very nice Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 18, 2010 Share Posted November 18, 2010 Excellent job. How long did it take you do? and how much would you charge to do a similar job for someone else? Cheers Dave Quote Link to comment Share on other sites More sharing options...
xecoupe Posted November 18, 2010 Share Posted November 18, 2010 well done! superb job, keep up the great work , Adie Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted November 18, 2010 Share Posted November 18, 2010 (edited) Fantastic work and great pics mate, it's well worth being in the club to access stuff like this, don't know why people lurk in the basic section. Quality repair Kev edit typo Edited November 18, 2010 by Kevin Abbott Quote Link to comment Share on other sites More sharing options...
Robbie Posted November 18, 2010 Share Posted November 18, 2010 Excellent Simon, knew when you got to this job it would be perfection Quote Link to comment Share on other sites More sharing options...
SCP Posted November 18, 2010 Author Share Posted November 18, 2010 (edited) Hi thanks all for comments on my project, I have been known to be a bit fussy with work on my car thats why I do the work myself and take my time then if its not right I know who to blame, dont think I could take on another as its a job to find the time for mine sorry Dave.I have got the driver side to do next at least it should be easier as I have the correct side rail this time thanks to Kev .Its definitely worth being a OMOC member as thats where I sourced the parts that are getting very hard to find now, also the friends made from all over UK and of course Billing still enjoyed even though this year I had started stripping down the Manta so had to bring the Vectra . Edited November 18, 2010 by SCP Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 19, 2010 Share Posted November 19, 2010 I think a lot of Manta's go to the scrapyard because the skill to repair them is in very short supply, when it comes to structural repairs. As you say "bits" are also hard to find nowadays. Keep up the good work. Cheers Dave Quote Link to comment Share on other sites More sharing options...
costasa Posted November 19, 2010 Share Posted November 19, 2010 Top work Is work like this that make me want to buy a mig welder and start to do some repairs in my manta. Cheers Samuel Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted November 19, 2010 Share Posted November 19, 2010 ditto to the above. yes excellent repair work. you have inspired me & possibly other people as well to remove any of my own repair pieces & re do them as you have. Quote Link to comment Share on other sites More sharing options...
welder Posted November 20, 2010 Share Posted November 20, 2010 Great job there. Quote Link to comment Share on other sites More sharing options...
SCP Posted January 13, 2011 Author Share Posted January 13, 2011 I thought it was time for the other side rail so I drilled out all the spot welds and removed the rail from rear to the upper sub frame mounting point then cleaned up the floor and painted ready for new rail, this side will be much more straight forward as I have the correct rail and wont have to fabricate parts as before Then I cut to the required length with a staggered front( to help with strength) cleaned and painted the new rail After aligning up the rail with my jig I welded it to the car through the old spot weld holes to keep the original look,here is the end result after grinding cleaning and painting I now have two new rails fitted My next job will be check and repair the jacking points and sills 2 Quote Link to comment Share on other sites More sharing options...
brianm Posted January 13, 2011 Share Posted January 13, 2011 Exellent work ,will be looking back at this when i go to do mine :thumbup Quote Link to comment Share on other sites More sharing options...
Shug Posted January 14, 2011 Share Posted January 14, 2011 You just removed the pride I had on the work I did on my own chassis Did you use shrinker/stretcher on any of the bits you made yourself or is it welded plates? Quote Link to comment Share on other sites More sharing options...
costasa Posted January 14, 2011 Share Posted January 14, 2011 Very good work, and the jig that you made is a very good ideia Work like yours and from another members made me to buy a mig welder, now i'm practice and hope to improve to do some work in my manta. This is a link from another site (retrorides" http://retrorides.proboards.com/index.cgi?board=usetharch&action=display&thread=70135 this was post from another member and this help me a lot to try to do the work Quote Link to comment Share on other sites More sharing options...
SCP Posted January 15, 2011 Author Share Posted January 15, 2011 You just removed the pride I had on the work I did on my own chassis Did you use shrinker/stretcher on any of the bits you made yourself or is it welded plates? I am quite pleased how it has turned out,I welded plates together to make the bends etc Cheers Simon Very good work, and the jig that you made is a very good ideia Work like yours and from another members made me to buy a mig welder, now i'm practice and hope to improve to do some work in my manta. This is a link from another site (retrorides" http://retrorides.proboards.com/index.cgi?board=usetharch&action=display&thread=70135 this was post from another member and this help me a lot to try to do the work Yes I had a good look on forums etc to see how other people were doing repairs for ideas before I started on my project Cheers Simon 1 Quote Link to comment Share on other sites More sharing options...
gary6303 Posted January 15, 2011 Share Posted January 15, 2011 great work mate, the hardest part of manta restoration made to look easy . Quote Link to comment Share on other sites More sharing options...
SCP Posted April 3, 2011 Author Share Posted April 3, 2011 (edited) I removed jacking points by drilling out welds then cleaned up the floor area above them just surface rust so not much to deal with I just couldn't reach it with Jacking points in place as I had a pair of new jacking points I fitted them to save cleaning the others up Edited April 3, 2011 by SCP 1 Quote Link to comment Share on other sites More sharing options...
SCP Posted April 3, 2011 Author Share Posted April 3, 2011 Now just a couple of finishing touches to chassis rails, a fuel pipe mounting welded on and brake pipe tags welded on Quote Link to comment Share on other sites More sharing options...
SCP Posted April 3, 2011 Author Share Posted April 3, 2011 (edited) On to my sills with rust bulges now ,I cut out rusty double skin area above rear jacking points then a bit larger area to make sure all rust was gone, in between the two skins was well rotten though most of sill is in very good condition then cleaned up the surrounding area welded in a new piece to join inner part to lower middle so I dont have a double skin at the bottom as this had caused my rust problems in the sill, then painted from a new sill panel cut out the section needed adjusted it with a hammer and drilled holes ready for welding, applied weld through primer welded it on ground off high spots and primed Edited April 3, 2011 by SCP Quote Link to comment Share on other sites More sharing options...
stradacab Posted April 4, 2011 Share Posted April 4, 2011 Nice work, if you are coming to Billing join us at Bristol for the convoy on the Friday! Quote Link to comment Share on other sites More sharing options...
SCP Posted April 6, 2011 Author Share Posted April 6, 2011 Nice work, if you are coming to Billing join us at Bristol for the convoy on the Friday! Hi stradacab yep I definitely will be going Billing looking forward to it don't like to mis the event of the year, sadly not in my Manta as it will still be in lots of pieces I will be going up earlier in the week so will see you at Billing Cheers Simon Quote Link to comment Share on other sites More sharing options...
Chappers11050 Posted May 4, 2011 Share Posted May 4, 2011 Looking good Dad! Quote Link to comment Share on other sites More sharing options...
midasmesh Posted May 4, 2011 Share Posted May 4, 2011 Its coming on well Simon keep it up. Don't know what i've been doing thou only just seen this post of yours. Quote Link to comment Share on other sites More sharing options...
