BarryD89 Posted November 28, 2022 Share Posted November 28, 2022 Back in 1989 when my Manta was ordered (presumably dealer stock) the owner never specified a near side mirror. He did go for a dealer fit rear wash wipe and an alarm system though. How easy is it to retro fit a near side mirror? I’ve seen a few on eBay but I’m not sure if I need a different fitting n the door. Or is it teeth clench and drill? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted November 28, 2022 Share Posted November 28, 2022 hi. you will need a n/s mirror .manta b,cavalier mk1,ascona b. this theoretically can be fitted to the existing corner piece (wont sit correct without some mods )but better to obtain the correct corner piece with the mirror indentaion/hole biult into it. someone on here will no doubt be akong to offer you one. or pop an ad in the wanted section. to fit it involves removing the door trim complete and unbolting the corner section with runner. there is one on ebay at the moment and the picture shows clearly why youre better off with the correct door mounting.and what you would need to shave off if you didnt . 2 Quote Link to comment Share on other sites More sharing options...
Mike. Posted November 28, 2022 Share Posted November 28, 2022 I did this job on my manta, just removed the interior handle, window winder and lock surround then removed the door card, I purchased the complete passenger mirror, corner trim and glass guide and swapped them out, easy job to do if you are able to source the parts. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted November 28, 2022 Share Posted November 28, 2022 Might have in the work shop definitely have a door mirror don’t know what side. ( little shed at the bottom of the garden) will have to look on Saturday as no lights down at the bottom of the garden. Quote Link to comment Share on other sites More sharing options...
BarryD89 Posted November 29, 2022 Author Share Posted November 29, 2022 21 hours ago, 1200bandit said: Might have in the work shop definitely have a door mirror don’t know what side. ( little shed at the bottom of the garden) will have to look on Saturday as no lights down at the bottom of the garden. Please, these no need. I’m not going to strip the door down just for a minor inconvenience when parking. Quote Link to comment Share on other sites More sharing options...
Mike. Posted November 30, 2022 Share Posted November 30, 2022 It is a really simple job to do. Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted November 30, 2022 Share Posted November 30, 2022 I didn't notice your car had a missing mirror. I thought all the later Mantas had both mirrors and it was only optional on the earlier cars (how the hell did people reverse park back then?) but you learn something each day. As above, I've done a "mirror runner" swap before and it is an easy job. If you get the part, you can see where the bolts go. Plus you could sell on the blank one to someone who wants the Englemann style 400 mirrors (which could also be an option for you, but means blanking off the driver side). If it's a case of not wanting the bother, like I've done with my Cavalier, you can order a universal clamp-on mirror which won't match and you'd obviously take it off at shows, but makes driving and parking so much easier. This is the one I use. You just clamp it to the gutter and with the mirror bolt loose, then hold the mirror in position as you tighten it. https://www.ebay.co.uk/itm/175388908144 2 Quote Link to comment Share on other sites More sharing options...
BarryD89 Posted November 30, 2022 Author Share Posted November 30, 2022 1 hour ago, Rick-Manta said: If it's a case of not wanting the bother, like I've done with my Cavalier, you can order a universal clamp-on mirror which won't match and you'd obviously take it off at shows, but makes driving and parking so much easier. This is the one I use. You just clamp it to the gutter and with the mirror bolt loose, then hold the mirror in position as you tighten it. https://www.ebay.co.uk/itm/175388908144 Good option, and addresses the reverse park challenge and roundabout menace (well it is Milton Keynes) 2 Quote Link to comment Share on other sites More sharing options...
Vince Posted December 1, 2022 Share Posted December 1, 2022 11 hours ago, BarryD89 said: Good option, and addresses the reverse park challenge and roundabout menace (well it is Milton Keynes) Well then you'll be glad to hear I work for Milton Keynes Council and we've just installed a new roundabout on the H9 for you to practise on.🤣🤣🤣🤣 4 Quote Link to comment Share on other sites More sharing options...
plumster Posted December 1, 2022 Share Posted December 1, 2022 Can't remember exactly, but my passenger side mirror is a relatively new addition, most Manta front door runners will have the relevant hole. It must be easy or I wouldn't have bothered. 2 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted December 1, 2022 Share Posted December 1, 2022 As @Rick-Mantasays the one you have with no hole may be quite desirable to someone fitting Englemann mirrors. I suspect they would pay a premium for it. 2 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted December 11, 2022 Share Posted December 11, 2022 Nearside mirror with all the fixings, runner, triangle mounting the whole shebang real easy job available from me at £40 plus postage and packing dep where you are ? 1 Quote Link to comment Share on other sites More sharing options...
BarryD89 Posted December 12, 2022 Author Share Posted December 12, 2022 9 hours ago, MrCarlos said: Nearside mirror with all the fixings, runner, triangle mounting the whole shebang real easy job available from me at £40 plus postage and packing dep where you are ? Message sent. 🤓👍 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 12, 2022 Share Posted December 12, 2022 2 hours ago, BarryD89 said: Message sent. 🤓👍 I’ll be interested in the blank one when you get it changed Barry 1 Quote Link to comment Share on other sites More sharing options...
BarryD89 Posted December 12, 2022 Author Share Posted December 12, 2022 Sure thing Jess, likely to be spring / May before I fit it though. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 12, 2022 Share Posted December 12, 2022 1 hour ago, BarryD89 said: Sure thing Jess, likely to be spring / May before I fit it though. No rush, whenever tbh. Car won’t be off spit till 2030 rate I am getting on with others lol 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 12, 2022 Share Posted December 12, 2022 4 hours ago, Jessopia74 said: Car won’t be off spit till 2030 rate I am getting on with others lol Wanna race? Could do with a deadline......2030 sounds ok 👍 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 12, 2022 Share Posted December 12, 2022 3 hours ago, ®evo03 said: Wanna race? Could do with a deadline......2030 sounds ok 👍 No, cos I will have prob bought another before then lol 2 Quote Link to comment Share on other sites More sharing options...
