Cavalier 4 door
Snowy
a post facelift GTE could be 26 years old now, and when they were first produced it was basically a '60s engine design with a '70s injection system in an '80s take on the original body.
Yep, modern !! I faff about with late 30s to 50s stuff as well as the mantas, its all modern to me past about 67 !!
  • Replies 168
  • Created
  • Last Reply
Top Posters In This Topic
where did you hide the BBS wheels when i was down
that motor will be a great daily driver if not too good to be every day usage
You'd be supprised what will fit in my garage...Those wheels are going on the cavalier with 205 50 15 tyres.
I love the work that is going on with this car, its going to be a real sleeper when its done, bigger engine and modern car go in an old looking shell.
The engine that came out was a 2L CIH. The only reason i'm putting the GTE engine in is because i wanted the five speed gearbox and i do not like carbed cars.
When i have converted to standard GTE fuel injection in the past i have increase enconomy by 9mpg.
This car is my daily driver. Just getting it how i want it.
Thanks for the comments.
Well the engine is in and nearly all wired up.
Had it fire on a burst of easy start so i'm getting a good spark. So fit some fuel lines tomorrow and see what happens...
This engine is just to test all the wiring etc. A freshly rebuilt engine will be going in soon.
Anyone got any good pointers to flowing the CIH head at all? Or any other mods worth doing to a 2l CIH?
Thanks
I have spoken to the guy before christmas about the panel but need to give him a ring soon to arrange going up to get it.
The car lives....Had it running today at last..
Plumbed the fuel pump in the boot for now after running copper pipes under the car for fuel lines..
I'm not happy with it's location so i'm going to move it to underneath the car. I was just having one of my lazy moments again.
Oh and for who ever it was who asked, here is what i do for the fuse for the fuel pump...
.. as i dont like adding to that standard fuse boxes as they are crap..
Well i have been out and about in it today and all seems good. So next onto the body work while i finish rebuilding the new engine for it.
Putting a valver in would be easy. I think the cih engine is more fitting for the cavalier. I'm sort of running on the theme of 'this is what vauxhall should have done at the time'.
Well i have been using the cavalier all week putting just over 300 miles on the clock. I would recommend this conversion to anyone with a four speed carbed CIH engine.
With the addition of a fith gear and standard gte fuel injection i now have perfect cold starting, a smoother running engine and i have increased mpg by 25%.
Although i'm not sure if the car is as quick. It may be an illusion as the car is more quiet on the move now.
If you buy a doner car like me it wont even cost you a thing. Buying that GTE hatch to use for the conversion paid for everything and more.
Would members like me to put a how to on a GTE conversion and/or stud removal techniques for the magazine?
I have two snapped threads in a thermostat housing at the moment, the one i took off, which might be of interest?
I FEEL A LITTLE SAD...
I remember going to Kettering to rescue this Blue Manta Hatch or it was going to be wieghed in,we got it running again but never quite got it back on the road.
Then someone looking for a Manta project knocked my door and it went to Luton, 18 months ago i had to rescue it again after it had been swopped for a Calibra and was under threat of being wieghed in again.
Then i had to have a car clearout and it went to Elesmere,Shropshire.
All this said,it was a REALLY SCRUFFY Manta and though on the face of it fairly solid now looking at it apart it would have taken huge amounts of work to restore and its provided parts to other Manta's?Cavaliers to keep them going.
Ian there was nothing solid about this manta. Also the worst of it were the really poor repairs that had been carried out that would all have needed re doing.
I dont just scrap mantas for fun. More often than not i save all i get.
Digital photos have a habbit of making cars look a lot better than they are.
At least when i say i've stripped a car i mean it. Not one single usefull part from this car will end up in the scrap yard.
As i said it was a REALLY SCRUFFY Manta but on the face of it fairly solid,but then i've seen many a Manta that appears not too bad but when you dig around they haven't got any bottom in them,these are past saving.
When you've crossed paths with a car several times you tend to get nostalgic but at least by saving it each time its kept it together as a complete set of parts till someone could make use of them,the efforts over the years haven't been wasted.
I would be really interested in the wiring one as i know nothing about wiring. Im trying to go the opposite of you by putting bike carbs on a 2.0 8v. Using the bike pump controlled with a switch on the dash. I cant figure out how to get it wired for the life of me.
Where did you get the fuse boxes and stuff, never seen anything like those before.
Cheers
Dave
You can get the fuse boxes from any decent motor factor. Demon tweeks sell them, vehicle wiring products and my local motor factor for example.
Why do you want to control the fuel pump from a switch on your dash?
Are you fitting this to a GTE or 1.8 shell? What managemant system are you going to run for the ignition? Or are you sticking with a 1.8 manta set up?
Sorry i Forgot to say that it is going in an 1.8 shell (hatch) so no pump fitted already. I was intending to use the bike pump mounted under the bonnet.
I was told that using it through a switch on the dash would simplify the install and act as a kind of immobiliser. It would also give me the correct 3 bar pressure for the carbs(?). (not sure if mounting it in the engine bay would be too much strain for it to be fair). There is no space for the facet pump on the head as it came from an injection. Although at the minute its got the 1800 head on till i get the manifold made at Bogg bros. But ive been told despite physically fitting, this is too small port wise to ever run properly.
I wouldnt know what to wire the pump to to run when the ignition is on, do you think you can use the standard gte relay somehow or a modern equivalent?.
As far as im aware i can get away without any ecu or management system at all. I may consider it later for better fuelling and response, it just plugs straight into the port on the carbs apparently.
Cheers for any help im a car fiddling novice.
