IanG Posted May 2, 2022 Author Share Posted May 2, 2022 Car came with a few bits, job for tomorrow! Just now, IanG said: Car came with a few bits, job for tomorrow! Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted May 2, 2022 Share Posted May 2, 2022 On 26/04/2022 at 14:31, IanG said: Been searching does anyone do inner rear arches/repair panels? Most posts seem to suggest fabricating a repair. Will stop cluttering up the thread and next time go to parts wanted! I used another wheel arch repair to do repair look on my cavalier resto 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 3, 2022 Author Share Posted May 3, 2022 (edited) Meant to add apart from the steering rack issues and petrol fumes the car was great, the 2.0 engine pulls really well with the auto box, checking under the bonnet someone has fitted a Weber twin choke. Just now, IanG said: Project images are available to Club Members Only, Click to become an OMOC Member. Edited May 3, 2022 by IanG 3 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 3, 2022 Share Posted May 3, 2022 hi. yes the 2.0 and autobox is a good combo. (once had an ascona auto with a 1.6 ,that was definately lacking thou) lots of people slate the autobox but its a tried and trusted design that been around for years and works well when in good order. i have a 2.2 auto in mine and thats even better.(and more economical too !) when or if you get to check your steering rack just make sure that it is actually faulty or worn.they usually last well and dont give much trouble.obvious places to check are outer and inner joints and the adjustment preload too.if you get a recon rack you dont always get a good unit.sometimes they still have the original bush on the paasenger side end. they can wear giving a lot of up and down movement. if you are running standard wheels and tyres and standard springs you should set it up to aim for around 2-3 mm toe in. 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 5, 2022 Author Share Posted May 5, 2022 Before I start work, someone confirm the steering rack bolts on from behind the crossmember? If not I have a sheared bolt passenger side! 1 Quote Link to comment Share on other sites More sharing options...
Michael mcinerney Posted May 5, 2022 Share Posted May 5, 2022 11 minutes ago, IanG said: Before I start work, someone confirm the steering rack bolts on from behind the crossmember? If not I have a sheared bolt passenger side! Correct bolts from behind crossmember. Was only looking at my own last night 2 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 5, 2022 Author Share Posted May 5, 2022 12 minutes ago, Michael mcinerney said: Correct bolts from behind crossmember. Was only looking at my own last night Phew that’s a relief! 1 Quote Link to comment Share on other sites More sharing options...
plumster Posted May 6, 2022 Share Posted May 6, 2022 On 02/05/2022 at 20:18, Kurtupsin75 said: I used another wheel arch repair to do repair look on my cavalier resto Same here, bodyshop used another pair of outers to make really tidy inner wheelarches. 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 7, 2022 Share Posted May 7, 2022 On 05/05/2022 at 14:00, IanG said: Phew that’s a relief! The steering rack bolts should have a tab washer on them. Often difficult to see if covered in oil & crud 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 7, 2022 Author Share Posted May 7, 2022 (edited) Quick update, four jobs to do over the next week, replace the rotten fuel tank breather pipes, fit the new steering rack and track rod ends (nos unipart rack from eBay), check the prop and diff for play to stop the clonk when selecting drive & reverse and get the rad re-cored as it’s leaking badly, had a very helpful chat with Northern Radiators at Leeds. Then I can drive it a bit more! Edited May 7, 2022 by IanG 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 7, 2022 Share Posted May 7, 2022 On 02/05/2022 at 08:42, ®evo03 said: Was wondering recently if later cars where painted underneath, as I think earlier cars have body colour paint underneath. Original, from the factory. Also wondered if people ever had issues with previous weld repairs, I haven't been around long enough to witness issues with previous repairs. Northern are great tbh, he has my rad there currently for refurb. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 7, 2022 Share Posted May 7, 2022 didnt know they were still going. they used to do a repair service on fuel tanks called "renew" with a lifetime warranty (hopefully!). my hatch tank was done many moons ago . 2 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 7, 2022 Author Share Posted May 7, 2022 10 hours ago, IanG said: Quick update, four jobs to do over the next week, replace the rotten fuel tank breather pipes, fit the new steering rack and track rod ends (nos unipart rack from eBay), check the prop and diff for play to stop the clonk when selecting drive & reverse and get the rad re-cored as it’s leaking badly, had a very helpful chat with Northern Radiators at Leeds. Then I can drive it a bit more! Fuel lines done today, radio fitted, cigarette lighter refitted, dash wiring loom tidied up, boot light repaired, good to tick a few things off the list - which keeps growing! Might try to fit the rear seat belts tomorrow, and plant some veg as everything keeps growing, must be that time of year! Project images are available to Club Members Only, Click to become an OMOC Member. 3 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 7, 2022 Share Posted May 7, 2022 (edited) Nice to see a flush radio! The only one I ever had that was flush in the past was from blaupunkt and it cost a weeks wage back in the day! These modern retro ones are snazzy 😎 3 hours ago, cam.in.head said: didnt know they were still going. they used to do a repair service on fuel tanks called "renew" with a lifetime warranty (hopefully!). my hatch tank was done many moons ago . Yeah, i]they are still doing fuel tanks. He made a point of mentioning it to me. Edited May 7, 2022 by Jessopia74 2 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 8, 2022 Share Posted May 8, 2022 thats good then because as we all know finding a good hatch tank is hard these days. 1 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 8, 2022 Author Share Posted May 8, 2022 3 minutes ago, cam.in.head said: thats good then because as we all know finding a good hatch tank is hard these days. Once upon a time you could just go to the scrappy, not these days! 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 8, 2022 Share Posted May 8, 2022 1 hour ago, IanG said: Once upon a time you could just go to the scrappy, not these days! Sadly that us due to the rarity of the Manta. They are too rare really for a big aftermarket following, meaning the pattern manufacturers basically want their costs covering for making any die. Like the Battery tray deal - we needed a large initial order before they would be viable. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 9, 2022 Share Posted May 9, 2022 so the best deal is either the "renew" system or maybee even finding a modern tank of similar dimentions to fit in its place ? some would say a custom tank could be made also ? at least its only hatches. saloon / coupe tanks dont rust ! 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 9, 2022 Share Posted May 9, 2022 Think you can get a 30L spare wheel can't that would work with a hatch, not a coupe. I did look at a cav mk3 calibra tank but was told too many mods, 1 good point, they are plastic. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 9, 2022 Share Posted May 9, 2022 You could definitely get a custom tank made to fit in the space, that is a fact but it’s the cost I guess for the 1off. Quote Link to comment Share on other sites More sharing options...
IanG Posted May 12, 2022 Author Share Posted May 12, 2022 (edited) Well, a few weeks into having a cav after 30 years since the last one and I’ve learnt a lot already, thanks for the good advice from the forum, this weekend rad comes out for refurb, and a bit of cleaning and tinkering! Edited May 12, 2022 by IanG 2 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 13, 2022 Author Share Posted May 13, 2022 How easy is it to convert the GL to GLS 6 dial dash, I assume I may need lots of sender units? Quote Link to comment Share on other sites More sharing options...
Trooker Posted May 13, 2022 Share Posted May 13, 2022 26 minutes ago, IanG said: How easy is it to convert the GL to GLS 6 dial dash, I assume I may need lots of sender units? Might be worth looking here https://mantaclub.org/forums/topic/32480-manta-b-instrument-panel-with-rpm-dial-pinout-needed/ 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 13, 2022 Share Posted May 13, 2022 hi. easy enough to convert . you will need 6 dial dash obviously !(with the half moon connector plug if poss) 2 terminal oil pressure sender unit, (either the correct fine thread unit and angle adaptor or a course thread type and fit it above the oil filter into the blank plug there) the main dash connector you have now can be re-used but you have to relocate the wires as for some stupid design they are all different on a 6 dial dash ? i did have the pinout and colours somewhere BUT if you get a cut off of wires with your new dash with plug on the colours will speak for themselves . you then just need 2 wires extra to engine compartment. one to the coil green wire for tacho and another for the oil pressure extra wire. if you get an age related dash your existing speedometer will fit in . hope this helps a little 3 Quote Link to comment Share on other sites More sharing options...
IanG Posted May 14, 2022 Author Share Posted May 14, 2022 Found out today why radios reception was rubbish aerial lead plug into radio looked someone had wired it in blindfolded, new lead fitted and all is well. Radiator is out now ready for refurb, trans oils pipes securely protected. Found out the carb is indeed a Weber complete with a leak on the top housing, another job for eBay……. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
