paulmanta Posted April 10, 2023 Author Share Posted April 10, 2023 6 hours ago, seanpren said: Grey trim from a gte, and for the belt I'm not sure but it's from an 1986 Manta GTE. Think it's the larger type though Can you count the splines on the shaft the winder goes on? there are two different types and I am not sure if they vary but could be the same colour, I know the earlier ones were one sort of spline but Its better to ask now. Ill look at the seatbelt box later too. see what I can find. Quote Link to comment Share on other sites More sharing options...
seanpren Posted April 10, 2023 Share Posted April 10, 2023 7 hours ago, paulmanta said: Can you count the splines on the shaft the winder goes on? there are two different types and I am not sure if they vary but could be the same colour, I know the earlier ones were one sort of spline but Its better to ask now. Ill look at the seatbelt box later too. see what I can find. Great thanks but it's the door handle not the winder I'm looking for lol. Will have a look at the car tomorrow when I'm out there and see if there's a GM number on the belt, thanks so much Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 10, 2023 Author Share Posted April 10, 2023 3 hours ago, seanpren said: Great thanks but it's the door handle not the winder I'm looking for lol. Will have a look at the car tomorrow when I'm out there and see if there's a GM number on the belt, thanks so much Ahh, that will be me reading too quickly then ! I think i do, in GTE grey, Ill look for it and let you know. 1 Quote Link to comment Share on other sites More sharing options...
611 Posted April 10, 2023 Share Posted April 10, 2023 20 hours ago, Moonmonkey said: 👍 Found a sump, will get some pics in the morning for you. Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted April 10, 2023 Share Posted April 10, 2023 3 hours ago, 611 said: Found a sump, will get some pics in the morning for you. Brilliant thanks👍 Quote Link to comment Share on other sites More sharing options...
seanpren Posted April 12, 2023 Share Posted April 12, 2023 These are what I have anyways Paul if you have some spare 👍 Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 12, 2023 Author Share Posted April 12, 2023 Yes, I should have belts with buckles to suit that. What is wrong with yours ? I have successfully fitted good belts to good mechs in the past when they have been chewed or the mech has been rusted up. So long as you don't let the reel unspring its actually really easy. If the spring has gone weak and the belt no longer retracts properly you can wind a couple of turns more tension in and it all works much better. 1 Quote Link to comment Share on other sites More sharing options...
seanpren Posted April 12, 2023 Share Posted April 12, 2023 I'm missing the buckle for one side and my drivers side belt the plastic adjuster/helper thing is broke. Belts are fine other than that though. I have a 2nd buckle fitted at the moment but it's from an early b and the belt won't clip in!! Let me know a price to include postage to ireland if that's OK Paul and I'll sort you out. Much appreciated Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 12, 2023 Author Share Posted April 12, 2023 I have the helper things separately, you can change them easily. Quote Link to comment Share on other sites More sharing options...
seanpren Posted April 13, 2023 Share Posted April 13, 2023 Legend. One of those, a buckle, Drivers interior door handle and if you've a grey trim piece for around the interior door lock if you have them. Mine must of grown legs and ran away 🤣 Quote Link to comment Share on other sites More sharing options...
611 Posted April 15, 2023 Share Posted April 15, 2023 On 09/04/2023 at 18:27, Moonmonkey said: Yes if you have one thanks Sorry its taken a while to get the pics!. Needs a good clean but its nice and straight and was on my engine, the only reason i took it off was that i had a nice powder coated one that i used when i rebuilt the 2.4. I kept this one as i was going to do the same with it but have not got around to it yet. Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 15, 2023 Author Share Posted April 15, 2023 On 13/04/2023 at 08:45, seanpren said: Legend. One of those, a buckle, Drivers interior door handle and if you've a grey trim piece for around the interior door lock if you have them. Mine must of grown legs and ran away 🤣 Right ! I have found some of it... Looking for the rest. Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted April 16, 2023 Share Posted April 16, 2023 21 hours ago, 611 said: Sorry its taken a while to get the pics!. Needs a good clean but its nice and straight and was on my engine, the only reason i took it off was that i had a nice powder coated one that i used when i rebuilt the 2.4. I kept this one as i was going to do the same with it but have not got around to it yet. Hi Andy sump looks good, tried to PM you but it won’t let me. Could you PM me details thanks Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 25, 2023 Share Posted April 25, 2023 Paul, do you have a weber carb for a CIH? Its for a 1.9 in an A but doesn't matter if its from a 1.6 or 2.0 as i can get it rejetted easy enough. Just having issues with the Solex thats on there currently. Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 25, 2023 Author Share Posted April 25, 2023 12 hours ago, mantasrme said: Paul, do you have a weber carb for a CIH? Its for a 1.9 in an A but doesn't matter if its from a 1.6 or 2.0 as i can get it rejetted easy enough. Just having issues with the Solex thats on there currently. Hi David, No, sorry, I gave up with used carbs a while ago and if I need one i tend to just buy a new one ! the cost is offset by the time and faff saving. I have a few carb inlet manifolds here though... Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 26, 2023 Share Posted April 26, 2023 11 hours ago, paulmanta said: Hi David, No, sorry, I gave up with used carbs a while ago and if I need one i tend to just buy a new one ! the cost is offset by the time and faff saving. I have a few carb inlet manifolds here though... Thanks, i stopped playin with carbs except bike carbs a while back too. Normally everything is on injection here but its more of an issue with a standard A series 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted April 26, 2023 Share Posted April 26, 2023 Dave- I’ve got a contact that could supply a new or refurbed Weber, specialist one man band. 1 Quote Link to comment Share on other sites More sharing options...
si-north Posted July 19, 2023 Share Posted July 19, 2023 Hey Paul. I’m looking for a GTE axle. May you have one about?? Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 13, 2023 Share Posted August 13, 2023 Looking for the lower alloy boss and the spring at the top of the steering column Quote Link to comment Share on other sites More sharing options...
seanpren Posted August 14, 2023 Share Posted August 14, 2023 Have you any of those fancy rad trays Clive used to make? Quote Link to comment Share on other sites More sharing options...
ALAN MANTA78 Posted January 17 Share Posted January 17 Do you have any rear lower repair panels for b coupe as mine need doing urgently can you point me in the right direction thanks in advance in the hope you can help Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 19 Share Posted January 19 On 17/01/2024 at 21:57, ALAN MANTA78 said: Do you have any rear lower repair panels for b coupe as mine need doing urgently can you point me in the right direction thanks in advance in the hope you can help Should be on eBay. Are these what you are looking for https://www.ebay.co.uk/itm/361946032883 might be worth adding a pic (from any car) and just highlighting what you need ? Quote Link to comment Share on other sites More sharing options...
ALAN MANTA78 Posted January 20 Share Posted January 20 Thanks for your info but I was trying to find lower side repair panels where the bumper bolt hole I have seen the ones you suggested but they don't seam to be right .I do appreciate your help 2 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 21 Share Posted January 21 https://www.ebay.de/itm/224446638298?hash=item34420fe8da:g:0TAAAOSw0T9cYEqf This ? they got both sides 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 21 Share Posted January 21 (edited) Great......... seller won't post 😂😂🤣 Edited January 21 by ®evo03 1 1 1 Quote Link to comment Share on other sites More sharing options...
