Secret Project Finished
Kevin Abbott
During the times I'm not at the Manta I have been doing these in the Lab.
The standard Exclusive headlights rust away and the retaining clips become brittle so I made an alternative.
New lights ordered and on the bench
Strip old ones and ultrasonic
Nothing worth using from these
Measure up and get new fittings
Grind and cut using a £600 hand piece :lol:
Bend tab
Fit
Secure
Add springs and cup washers
Fit to bezel
Job done
  • Like 3
I decided I wanted Engelmanns on the car but looking through the spares I realised I had only one mounting foot.
So I made my own using an original foot I poured a silicon 2 part material around it to make a mould
Test in cold cure acrylic
I assessed the first  one and thought it needed more strength so I modified the mould
Now done in chopped strand and resin
Oh they get warm
From the mould and ground flat on the water grinder
I may need to add reinforcement to the fitting point
To add to the stress the mancona returned to my Brothers
I have also found time to do a roof conversion in my conservatory using superquilt
Then to add to the fun my Brother turned up with this
Paint bay now looking like Retro Power
Edited by Kevin Abbott
A bit more ironing with some bog
This side has a full arch section added not by me and was a PITA to get straight
C123BC1A-EFEB-4C5F-BD30-C835917280A8_zps
Other side needed a little wipe to sharpen the lines
43E21C6A-7D23-4A80-B026-0175A4813DFF_zps
Wheels are off the GT, my brother said it made the car look like a gasser :lol:
3A0A4C7A-4790-410E-A40C-880F3717D459_zps
262A97AC-7A1D-4FE9-B0F1-56DF46CB3A77_zps
BA334A64-8715-4DA8-8336-737012D9990E_zps
7DFB917B-B98E-44EF-9FDF-CE491C0A98FE_zps
Prep takes a loooooooooooonnnnnnnnnnnggggggggg time
421AC45D-D3F7-404E-A22C-1925692C196C_zps
High spot
8BC4847B-3ED0-42B6-9B1F-8C8866A11F78_zps
Primer lashed on to make sure the lines are sharp and then add stopper if required
74FB01CC-0B02-47D7-B9E7-7E6824CAA7C9_zps
C0072658-D443-4838-AB1E-6401FEE9BF93_zps
8FAB563F-9E49-4780-AAC9-81EE6C1BEF2B_zps
Looking down the lines
33C1E8D6-20BA-458C-BFB1-AE48B8998A53_zps
  • Like 4
Where's your face mask young man???? tut, tut, tut.
At my place there would be a stewards enquiry & a dozen H & S nobs running around with their pants on fire.
What a grand job you are doing.
Dialling in the lines has taken longer than the welding!
With a bit of luck it will be FM Red by bank holiday monday.
5D45E907-F519-422E-8553-97C0D2C3DCEF_zps
81D27E54-2D89-4720-A3BE-B34975D06AC9_zps
5773C227-7C40-4C7F-9720-D57D11A3CF61_zps
6E63D960-7A72-4D6D-92EB-25F45F615B07_zps
This side is the one with the replacement arch and took nearly a week to get right!!
7A39035D-B15A-4B9A-8375-FDCD15298E64_zps
F8583FAC-7CF2-4740-9707-559F40071835_zps
727F1158-46B8-4573-B253-D524A764391C_zps
0A0D3C3A-1B20-4CDC-9F12-D65B5DD177DB_zps
88923722-D9DF-42F5-9963-EC0F3BF4685C_zps
01C7FEE6-8AB9-4919-AD80-87DBE06E7A06_zps
8358F6A4-1A31-4EE5-8033-2D1605E9CD87_zps
A lot of area guide coat and wet flat now
48001844-0A91-4975-92B0-4B72DD25A10A_zps
Some new parts in from Germany
151A7973-D47B-4169-AED1-909AEFFFA5E8_zps
4BC31A4E-10E0-40EE-B112-056F2CE05AB0_zps
This is the car that gave me the bug back in 1998, my 16v coupe.. I loved that car
7B960593-F6AD-4FE7-8A41-3511F6D982C9_zps
  • Like 3
