1200bandit Posted August 8, 2021 Author Share Posted August 8, 2021 Remove the alarm today,had to remove the dash as it was wired into all kinds of stuff.some wiring not connected to anything Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
Titson Posted August 8, 2021 Share Posted August 8, 2021 W G Grose, Kingsthorpe. Bought her new when I traded my Berlinetta hatch in. I bought the hatch new from the Vauxhall Opel dealer Croyland Motors in Rushden at the time. 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 11, 2021 Author Share Posted August 11, 2021 On 08/08/2021 at 20:08, Titson said: W G Grose, Kingsthorpe. Bought her new when I traded my Berlinetta hatch in. I bought the hatch new from the Vauxhall Opel dealer Croyland Motors in Rushden at the time. Thanks for the information, Always interesting to get some history Had the manta for a week now the little jobs have mounted up When l got the manta it smell like it was over fuelling When l dropped the coolant the alloy T piece fell to bits ( top with water will replace the coolant) also blocked T piece throttle body not getting hot So made one up ( temp one) run the engine hot running a lot better ( no smell) . Made a better one now ,hopefully will not leak Found some keys on eBay ( £7.00) just got to get them cut When l removed the alarm the bolts where solid on the inner wing ,had to rip it off ,so the inner wing will need welding Got some carpet for the boot so that will it look a lot better Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
fullsunian Posted August 12, 2021 Share Posted August 12, 2021 With regards the upside down pictures, if you are using an iphone make sure the volume controls are at the bottom. that should fix the problem👍 Great tread by the way and nice to see one come back from over the water. Ian 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted August 12, 2021 Share Posted August 12, 2021 On 08/08/2021 at 20:08, Titson said: W G Grose, Kingsthorpe. Bought her new when I traded my Berlinetta hatch in. I bought the hatch new from the Vauxhall Opel dealer Croyland Motors in Rushden at the time. I was bought up opposite there. Was a Lada dealership during my childhood from my earliest memory. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 12, 2021 Author Share Posted August 12, 2021 Some more bits done Got the dash lights working, removed the white plastic bits much better Give the coolant system a good flush out with water( more pink coolant flush out) replaced the T piece ( made from plumbing pipes) cost about £5.00 Fill with water again run it hot , hopefully no more pink coolant When removed the temp T piece found pink curd on the alloy side the T piece, the copper side clean Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 12, 2021 Author Share Posted August 12, 2021 8 hours ago, fullsunian said: With regards the upside down pictures, if you are using an iphone make sure the volume controls are at the bottom. that should fix the problem👍 Great tread by the way and nice to see one come back from over the water. Ian Hi lan l am on a iPad, so can’t take photos upside down on most things Only happening on here Quote Link to comment Share on other sites More sharing options...
Trooker Posted August 12, 2021 Share Posted August 12, 2021 48 minutes ago, 1200bandit said: Hi lan l am on a iPad, so can’t take photos upside down on most things Only happening on here Different forums can treat metadata differently. I notice your pictures are all in Landscape, are you left handed? I just ask because if you are, you’ll probably click the home/photo button with your left thumb but to the iPad programmer of 2012 or whatever it was that’s upside down & the iPad photo could be ‘telling’ this forum which way is ‘up’ 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 12, 2021 Author Share Posted August 12, 2021 I am right handed . The photos are correct in the photo album The iPad will spin the image the correct way around when a photo is taken The business card come out correct on here is that l had put the card upside down 😶 Quote Link to comment Share on other sites More sharing options...
Trooker Posted August 12, 2021 Share Posted August 12, 2021 2 hours ago, 1200bandit said: I am right handed . The photos are correct in the photo album The iPad will spin the image the correct way around when a photo is taken The business card come out correct on here is that l had put the card upside down 😶 This is as bad as tracing an air leak on a manta 😂 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 13, 2021 Author Share Posted August 13, 2021 At least you can use brake spray to find a air leak l have no clue about iPads, computers Will have give to my mate to sort out when time , COVID-19 aloud 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 13, 2021 Share Posted August 13, 2021 Apple decided that when you capture a photo with the volume buttons facing skyward, like most people do since we're used to camera shutter buttons being on top, this is actually upside down. Apple also wants to keep the process of capturing and saving a photo to be as fast as possible so you can keep snapping away. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 13, 2021 Author Share Posted August 13, 2021 Will try and take some photos with the volume buttons at the top. Only did small bit of work tonight ( is whiskey night) Fitted boot rubber ( from a Nissan xtrail is a bigger ) fitted very well Are trying to fit a Renault Clio rubber carpet mat looks okay more cutting required. Also got red LED light which are going to try a wire into the boot light so when the boot is open the will be a very bright red light ( got to work that bit out) Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 14, 2021 Author Share Posted August 14, 2021 Dropped the water ,coolant out running clean, run engine hot heater pushing out hot air Fitted the rad cover (home made one) hopefully will not fall apart when it gets wet. Clean out the boot,got the boot light working,fitted a red LED into the boot Project images are available to Club Members Only, Click to become an OMOC Member. Just now, 1200bandit said: Dropped the water ,coolant out running clean, run engine hot heater pushing out hot air Fitted the rad cover (home made one) hopefully will not fall apart when it gets wet. Clean out the boot,got the boot light working,fitted a red LED into the boot Project images are available to Club Members Only, Click to become an OMOC Member. A big thanks to evo03 and everyone the photos come out the right way round 1 minute ago, 1200bandit said: Project images are available to Club Members Only, Click to become an OMOC Member. A big thanks to evo03 and everyone the photos come out the right way round 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 15, 2021 Author Share Posted August 15, 2021 Not much done today so far, got the interior light working LED light is bright ( thinking if the boot is open on dark night it will be visible) And now the photos are definitely coming out okay Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 15, 2021 Share Posted August 15, 2021 lol that boot scares me now, I am such a snow-flake 😂 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 15, 2021 Author Share Posted August 15, 2021 It does look like the portals to the devil’s place Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 15, 2021 Share Posted August 15, 2021 Or the entrance of a gentleman’s club. 😉 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 15, 2021 Share Posted August 15, 2021 1 hour ago, Jonathan Pounsett said: Or the entrance of a gentleman’s club. 😉 I would not know 🙈🤣 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 15, 2021 Share Posted August 15, 2021 2 hours ago, Jonathan Pounsett said: Or the entrance of a gentleman’s club. 😉 Hatches are better! On 14/08/2021 at 21:10, 1200bandit said: Project images are available to Club Members Only, Click to become an OMOC Member. A big thanks to evo03 and everyone the photos come out the right way round Gonna miss turning my screen upsidedown to view! Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 16, 2021 Author Share Posted August 16, 2021 Put a coat of paint on the boot floor.Looking a lot nicer Will not see when all the carpet is fitted Anybody know of something thar will cover the fuel tank Found headlight adjustment kit on eBay.will they fit a twin headlights Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
paulmanta Posted August 16, 2021 Share Posted August 16, 2021 That headlamp kit is no good for the twin lamps. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 16, 2021 Author Share Posted August 16, 2021 49 minutes ago, paulmanta said: That headlamp kit is no good for the twin lamps. Is the a kit available from somewhere Quote Link to comment Share on other sites More sharing options...
paulmanta Posted August 16, 2021 Share Posted August 16, 2021 Depends on the type of lens used. I replace all of mine with new hella 1L300 2850-06 units. I put 4 in, so you get 4 sidelights as it looks better, I wire up the dip as outside and main as inside but use a front fog lamp switch to have the outer mains come on if I want. Simple stainless threaded bar and little hooks put on the end made from the stainless inserts you get in windscreen wipers along with new stainless compression type springs hold them in. You can use the original plastic nuts to adjust if you use the right threaded bar. 1 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 16, 2021 Author Share Posted August 16, 2021 The headlights are bounded in . Will have to remove the lights and make my own ones Project images are available to Club Members Only, Click to become an OMOC Member. 1 2 Quote Link to comment Share on other sites More sharing options...
