Shug Posted December 1, 2008 Author Share Posted December 1, 2008 Managed to spend all weekend getting just the following done (albeit sunday with a lethal hangover. Whisky would you believe ) (the head isn't bolted on. Doesn't even have a cam in it yet. I just wanted to pretend it was finished! Incidently, is the head gasket supposed to be blocking most of the channels between head and block? Old one on it was, and new one would as well) Thats all til the xmas holidays where I will get two hangover fuelled weeks solid at it. It's what christmas is all about Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 1, 2008 Share Posted December 1, 2008 Shug Incidently, is the head gasket supposed to be blocking most of the channels between head and block? Old one on it was, and new one would as well) Yes that is normal, or at least on all the ones i ahve done. What ever you do though, dont forget the rubber o ring between the head and timing case at the front. Quote Link to comment Share on other sites More sharing options...
Shug Posted January 14, 2009 Author Share Posted January 14, 2009 Just realised I haven't updated since xmas hols. Prob cos there's not a huge amount to see, but here it is: Firstly, one largely completed engine (alternator at local tech college for testing!) One tastefully painted arch One shagged bonnet Boot lid needed a little work (yes, thats fibreglass ) Got a coat of filler as well. All holes nicely sealed up. So thats what its supposed to look like! Drivers door needs a bit of work. As does the passenger one: (I just like to pretend its closer to completion! Its not attached) Oh, and this is how cold it was outside, and I was in a large wooden shed Next job is apply new slide hammer to a piss poor repair I made early on( perfectly solid and strong, just not pretty), and use pdr tools on doors and shell dents. Once alternator is back will finish engine, spray bay and drop it in. Then fix up gearbox ( or pay someone else to!) stick it in and measure and cut prop. Then sanding and filling and sanding aplenty to get shell for spraying. Then wire, pipe, and bung interior in and stick some glass on with a few other bits n pieces and its finished! Quote Link to comment Share on other sites More sharing options...
Robbie Posted January 14, 2009 Share Posted January 14, 2009 thats cold Shug, I aint been at mine since before xmas and getting used to the warmt inside now lol, need to get picked up and back to doing a bit i suppose in the next month or so. Your getting there bit by bit Quote Link to comment Share on other sites More sharing options...
Shug Posted March 2, 2009 Author Share Posted March 2, 2009 A quick pic of its current state: I can crawl underneath it now (and did, fitting two anti roll bar links to find out I've got a completely different anti roll bar to whats in haynes and dr-manta etc ) As george buehler* constantly says 'think ahead stupid!' (* boat builder and inspiration for my next project ) Quote Link to comment Share on other sites More sharing options...
Shug Posted April 19, 2009 Author Share Posted April 19, 2009 How to spot every single imperfection and flaw in a manta body shell in one easy step. Paint it black. Started the week with a car needing bodywork, did a week of bodywork, now have a black car needing bodywork. Confidence is at a new all time low. Nae manta for billing this year. Again. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted April 19, 2009 Share Posted April 19, 2009 That's why black used to be an optional colour with the same price tag as metallic as they used to have to mop the whole car as it shows every imperfection. Go white if dismayed and not wanting to get it perfect. Otherwise if it needs work everywhere hit it with 5 litres of filler primer........... worst case spray putty but you probably don't want to go there. And finally.......................... never listen to me. Quote Link to comment Share on other sites More sharing options...
Shug Posted April 20, 2009 Author Share Posted April 20, 2009 Its no actually that bad. Needs a spot more work. Touch of melodrama that was served on the side of my stonking hangover when that was posted to Spraying is easy. Dunno why people worry about it. Its all the sodding prep required that's annoying! Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted April 20, 2009 Share Posted April 20, 2009 Nice to see you making some progress Shug. Quote Link to comment Share on other sites More sharing options...
Shug Posted May 5, 2009 Author Share Posted May 5, 2009 Take one shiny gearbox, And after attaching to engine use precision engine crane, And drop into aforementioned black car, No much clearance between engine and shell at one end tho. Theres a distinct possibilty the engine mounts are on the wrong side. Gearbox mount not on yet tho, need to fabricate one. (held up with wood and rope just now ) Quote Link to comment Share on other sites More sharing options...
vealmonkey Posted May 7, 2009 Share Posted May 7, 2009 Starting to take shape , when are you hoping to get the manta on the road ? Quote Link to comment Share on other sites More sharing options...
Shug Posted May 7, 2009 Author Share Posted May 7, 2009 Starting to take shape , when are you hoping to get the manta on the road ? One day..... Need to start spending a heap of money on bits now, and courtesy of a temperamental dysfunctional audi, I don't have any! Quote Link to comment Share on other sites More sharing options...
Shug Posted May 17, 2011 Author Share Posted May 17, 2011 (edited) 2 years since last update and the ****** still aint finished. Has moved along a little bit tho. Brakes went on Shit paint job got redone Engine dolled up and carbs bolted on Lights on. Dash in (glovebox just lying there!) Swore a lot Windscreen in Other stuff on Wheels on with spacers and longer bolts. Headlining start halfway Mostly done bar a little trimming Chrome trim started to go on, rear windscreen in, carpets in as well, seat subframes sorted and fitted. Exhaust on. As it is now: Final jobs are clip hose and brake pipe on properly, fit r1 fuel pump as facet pump overfuelling carbs at times, fit stereo, fit rest of chrome trim, fit door seals, finish upholstering seats and fit them, adjust bonnet and boot, fit rear side windows and wash off the thick accumulation of dust and polish it before taking it for an MOT and hope no-one spots the glaring deficiencies of my work too much. Almost thinking no to bother taking it to billing if its finished in time. Glowing pride is absent somewhat and condemnation and coarse criticism can be done without. Edited May 17, 2011 by Shug Quote Link to comment Share on other sites More sharing options...
monzta Posted May 17, 2011 Share Posted May 17, 2011 Oh my gitty aunt What a project, have just viewed all pages, and i have one word... Respect! That first shell you had, i wouldn´t have touched that one myself either. Best choice i think to do what you did and get a bodyshell in better condition. The red one should have been sand blasted, but i have serious doubts about how much you would get back from the blasters ? I had a TE2800 replica once, i bought it only to get the wide wings and flares. And oh my god that thing was dead! When i opened the door the A post broke off! ! ! ! I then stepped on the side panel and that broke as well... And guess what happened when we cut off the rear flares (fibreglass).. Yup the entire rear end of the car hopped 2-3 inches down, and the rear windscreen popped out. So sometimes, its better to let them rust in peace Quote Link to comment Share on other sites More sharing options...
stradacab Posted May 17, 2011 Share Posted May 17, 2011 Coem on Shug, you gonna make it to Billing (with the car obviously!) cant wait to see it! Quote Link to comment Share on other sites More sharing options...
robah Posted May 17, 2011 Share Posted May 17, 2011 Thats coming along very nicely Shug. The wheels look brilliant on the car When you get despondent, look at the thread and what you have achieved, over the years. Wow I hope to see the car at Billing..................Please! Quote Link to comment Share on other sites More sharing options...
turbo16n Posted May 18, 2011 Share Posted May 18, 2011 Good work Shug,keep it going,the finish line is in sight Quote Link to comment Share on other sites More sharing options...
manta400john Posted May 18, 2011 Share Posted May 18, 2011 Hat off to you Shug, one hell of a project. When it hits the road it'll be a two fingered salute to the Audi John. Quote Link to comment Share on other sites More sharing options...
Shug Posted May 18, 2011 Author Share Posted May 18, 2011 Hat off to you Shug, one hell of a project. When it hits the road it'll be a two fingered salute to the Audi John. If I could afford to, the audi running gear would be going on the next manta As it is, its getting sold, or broken for parts depending on MOT at end of month. Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted May 18, 2011 Share Posted May 18, 2011 Yep Shuggers, you got to bring to billing, end of. Quote Link to comment Share on other sites More sharing options...
Rab Posted May 18, 2011 Share Posted May 18, 2011 Hi Shug. gid on yae another `A` saved and all doon tae yur hard effort in rebuilding,awe tak mi hat aff tae yae. Quote Link to comment Share on other sites More sharing options...
mantaray Posted May 18, 2011 Share Posted May 18, 2011 As Rab has said, It is another A saved. It does not matter if the car is not showroom condition, how can anyone expect it to be, you are a DIYer and not profectional. Personaly I have more repect and enjoy home builds over Profestionals anyday. You must bring it to billing if finished and be prowed of your achevments. :thumbup Quote Link to comment Share on other sites More sharing options...
midasmesh Posted May 20, 2011 Share Posted May 20, 2011 Yep its looking good Shug. Can i ask what dizzy you are running with the bike carb set up ? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted May 20, 2011 Share Posted May 20, 2011 If I could afford to, the audi running gear would be going on the next manta As it is, its getting sold, or broken for parts depending on MOT at end of month. DON'T BREAK IT, ENJOY IT!!!!!!!!!!!!!!!!!!!!!!!! If this is because you are dissapointed at the cosmetics don't despair you have done te hard bit. You can always shop around for someone to do the final pudding and spray at a reasonable cost. There will be someone around that will do you a nice job for two or three hundred as you have it rust free so they won't have to rub a thousand scabs down. Quote Link to comment Share on other sites More sharing options...
Shug Posted May 20, 2011 Author Share Posted May 20, 2011 Yep its looking good Shug. Can i ask what dizzy you are running with the bike carb set up ? At the moment its mantadocs 2.0 dizzy When I get mine sorted it'll be the standard 2.2 (which I'm sure is the same except for rotor arm) And dont worry mantadoc, I was referring to breaking the audi, not the manta!! Quote Link to comment Share on other sites More sharing options...
