Mike. Posted August 21, 2022 Share Posted August 21, 2022 I use the Disklok, it’s a bit cumbersome stored behind the seats, but at least some security when parked up. 2 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted August 21, 2022 Author Share Posted August 21, 2022 Car never far from me when I take it out .never leave it alone I'm having the car traced and tracked coming weeks I'm having hard wired £100 to install then it's 5.99 a month until I say stop 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 21, 2022 Share Posted August 21, 2022 3 hours ago, Kurtupsin75 said: Car never far from me when I take it out .never leave it alone I'm having the car traced and tracked coming weeks I'm having hard wired £100 to install then it's 5.99 a month until I say stop Oh that’s relatively cheap tbh then, did not realise they had dropped so much. Thinking old school, crook lock. But I was reading on FB and some dudes custom ford was pinched when it had tracker and he had even removed the steering wheel 😬 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted September 27, 2022 Author Share Posted September 27, 2022 Hi all hope your all well winter is coming time up grades quick question wots the best twin webers to get for 20s 40s or 45s .when can I obtain electric ignition from .thanks Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 27, 2022 Share Posted September 27, 2022 Easiest path for ignition is go with distributor and amp from a GTE, it’s a standalone Bosch setup and is pretty reliable. Depending what you want to achieve, but if your going for mostly drivability then a pair of Dellorto twin 40s (36mm choke) is very sweet. The Dellorto are a better carb than the Webber for road use, but it’s marginal. The bigger you go with carbs has a drawback, does increase BHP, but it will shift the torque curve upper rev range and not always the best thing for a daily car. Best option possible with ignition would be add TPS (sensor) to Carbs spindle, crank sensor/wheel to front pulley and go with No-Diz setup (fully mapped ignition curves). Also forgot to message you. Sadly Both the 2.4 manifolds I have are cracked underneath, so scrap. Apparently very common on the 2,4 one. 2.0GTE is a good upgrade and larger than the carb version, sorry I don’t have one of those mate. 1 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted September 27, 2022 Author Share Posted September 27, 2022 3 minutes ago, Jessopia74 said: Easiest path for ignition is go with distributor and amp from a GTE, it’s a standalone Bosch setup and is pretty reliable. Depending what you want to achieve, but if your going for mostly drivability then a pair of Dellorto twin 40s (36mm choke) is very sweet. The Dellorto are a better carb than the Webber for road use, but it’s marginal. The bigger you go with carbs has a drawback, does increase BHP, but it will shift the torque curve upper rev range and not always the best thing for a daily car. Best option possible with ignition would be add TPS (sensor) to Carbs spindle, crank sensor/wheel to front pulley and go with No-Diz setup (fully mapped ignition curves). Also forgot to message you. Sadly Both the 2.4 manifolds I have are cracked underneath, so scrap. Apparently very common on the 2,4 one. 2.0GTE is a good upgrade and larger than the carb version, sorry I don’t have one of those mate. No problem m8 I keep searching around thanks for tips on the cards most appreciated 1 Quote Link to comment Share on other sites More sharing options...
fullsunian Posted September 27, 2022 Share Posted September 27, 2022 I have gone down the twin 40's route with a pair of Dells. I used a GTE exhaust manifold and a pair of short Opel GT inlet manifolds, so I didnt have to move the servo or master cylinder. The inlets came from OpelGTsourse in the states. I struggled with the throttle linkage on the dells as it was touching the exhaust manifold at full throttle. Although Ive fixed that, Im still not happy with the set up. Even though the short manifolds saves moving the servo I still cant fit filters, so it gets noisy on acceleration lol As you can tell, its still a work in progress.... Sorry they are upside down.....its an iphone thing!😡 Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted October 2, 2022 Author Share Posted October 2, 2022 On 27/09/2022 at 11:24, fullsunian said: I have gone down the twin 40's route with a pair of Dells. I used a GTE exhaust manifold and a pair of short Opel GT inlet manifolds, so I didnt have to move the servo or master cylinder. The inlets came from OpelGTsourse in the states. I struggled with the throttle linkage on the dells as it was touching the exhaust manifold at full throttle. Although Ive fixed that, Im still not happy with the set up. Even though the short manifolds saves moving the servo I still cant fit filters, so it gets noisy on acceleration lol As you can tell, its still a work in progress.... Sorry they are upside down.....its an iphone thing!😡 Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Thanks for pics looks great Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted October 30, 2022 Author Share Posted October 30, 2022 This month's practical classics Project images are available to Club Members Only, Click to become an OMOC Member. 9 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted October 30, 2022 Share Posted October 30, 2022 Well done Keith, restorer of the year too 👍😎 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted October 30, 2022 Author Share Posted October 30, 2022 2 hours ago, Jessopia74 said: Well done Keith, restorer of the year too 👍😎 Thanks yes have to vote for that one 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted October 31, 2022 Share Posted October 31, 2022 Kurt, you should try getting some professional photos done, some of those tik tok guys, or social media dudes, Congrats on the mag article, makes a difference not being a ford. 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted November 20, 2022 Author Share Posted November 20, 2022 Brilliant time at nec meet some great members and people at the show really looking forward to next year's events cavalier of the road now time to make a few adjustments and improvements over winter nights .thanks to all organisers of club stand been awesome weekend looking forward to seeing everyone next meets Brilliant bunch of members .stay safe guys and girls . Project images are available to Club Members Only, Click to become an OMOC Member. 8 Quote Link to comment Share on other sites More sharing options...
Vince Posted November 21, 2022 Share Posted November 21, 2022 Here's some NEC photo's for you Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 6 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted November 21, 2022 Share Posted November 21, 2022 It looks cracking on the stand indeed, well done 😎👍 1 1 Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted November 21, 2022 Share Posted November 21, 2022 Fantastic car, a class of finish to aspire to. Well done. 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted April 28, 2023 Author Share Posted April 28, 2023 Hi all like to fit electric fuel pumb wot the best to obtain and psi .running 2 litre with 32 36 weber .thanks Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted April 28, 2023 Share Posted April 28, 2023 What’s wrong with the stock mechanical? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 28, 2023 Share Posted April 28, 2023 1 hour ago, Kurtupsin75 said: Hi all like to fit electric fuel pumb wot the best to obtain and psi .running 2 litre with 32 36 weber .thanks Stick with a trued and trusted FACET pump Kieth, best if you mount in back if possible but not 100% necessary. Getting it lowdown at the front though 2 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted April 29, 2023 Author Share Posted April 29, 2023 2 hours ago, Paul Barrett said: What’s wrong with the stock mechanical? Takes ages to start battery gets slow after turning over so many time to get fuel to carb after sitting more then 5 days . Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 29, 2023 Share Posted April 29, 2023 never had an issue with the original design. they do have a filter in some of them that can be cleaned or plenty of new ones on ebay too .some oem ones too. 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted April 29, 2023 Share Posted April 29, 2023 6 hours ago, Kurtupsin75 said: Takes ages to start battery gets slow after turning over so many time to get fuel to carb after sitting more then 5 days . Ah ok. Like Jess said a facet silver top etc will be fine. Don’t bother with the Chinese copies. id mount underneath at the back, rubber bobbins etc as can be a little noisy 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 29, 2023 Share Posted April 29, 2023 I have a cut out on the injections ,but is on the earth side of the wiring Most people look for a live feed to whatever system that it’s plumed into will put more security on it in the future 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted April 30, 2023 Author Share Posted April 30, 2023 Detailing time for vauxAlll meet Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. New tailored floor mats Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 3 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted May 15, 2023 Author Share Posted May 15, 2023 Window louvre now probably fitted Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 5 Quote Link to comment Share on other sites More sharing options...
